Text Object Justification Properties Reset Each Time
In Rhino 9 for Windows [may also be present on Mac, I have not tested] version 9.0.26300.09401, Text Objects reset justification properties each time the TextObject command is run.
This behaviour is different from Rhino 7, where a user can select centre-justified and middle-justified (for example) instead of the default left & top justified and these will remain set next time.
Example screenshots showing Rhino 9’s generated text objects versus Rhino 7. The first time, I manually selected my preferred justification, then Rhino 9 “resets” these after generating the first text object where Rhino 7 does retains both choices (left/centre/right and top/middle/bottom).
If this behaviour is an intentional change, consider this post a request to have this functionality reverted.
If this behaviour is a bug, please consider this post a bug report.
Thank you
