Found some weirdness with the Match Text component in Grasshopper.
Can someone explain why in this instance it is not just matching the character, but also “*” and “?”.
text match bug.gh (12.7 KB)
ps: what i am trying to do is get the index of each character in the input word from the list of characters.
Info from the posts linked below:
Patterns use the VB Like operator which supports:
(any single character)
(any number of characters)
(any single digit)
Text filter - Grasshopper (grasshopper3d.com)
If you set C to False then the casing of text is ignored. “B” is the same as “b”.
[help] About “Match Text” component – Grasshopper (grasshopper3d.com)
You could use the unicode values of the characters instead, but you would have to edit your Character list on the left side.
nathanletwory
(Nathan 'jesterKing' Letwory)
4
Since the mentioned characters are wildcard characters the easiest way is to ensure they are escaped. Note the backward slashes here:
Oh, of course, that makes sense. Good to know you can escape them though!
