Text Mask incompatible with layouts
I just found that when text-mask is set to background, in a layout the mask will be rendered and printed gray. Should on Layouts the text-mask set to background not be rendering white actually a better description would be “non-printing”?
The workaround is setting a solid color, yet that clutters the model views with white squares.
Thanks
-Willem
Right, it looks like ‘background’ is not paying attention to the paper color in the layout (Shows gray, i.e. View background) display but Print gets it right- does not show a gray rectangle there- Am I looking at the same problem?
Indeed it does, yet I was looking at text in details, those also do not print correct:
Thanks
-Willem
Hi Willem- got that, thanks.
Hey there, any news on this? I have noticed the same behavior in V6 :slight_smile:
You never use Copy-Paste? :sunglasses:
I found the YT issue and added a few comments. Feel free to review!
RH-21807
Sure I do! :grimacing:
Thanks wim
