Text inside block not printing in Layouts, when using Levels
Using Rh8 (8.9.24194) and VARQ3 (3.0.8.18917).
I created a simple Layout with 4 detail views, and restricted the visibility of Levels on each Detail. In the Model space I have a block that contains a text object, plus an exploded version of that next to it.
Already the Print Preview shows that the Text inside the block is not printed out in Levels higher than +0. The exploded one prints out ok. And the block prints ok, when all Levels are On.
The actual print is the same.
File for testing:
Print test Levels.3dm (682.9 KB)
Hi @Toni_Osterlund this issue doesn’t happen if you use the Hidden display mode inside each detail view. We will investigate why it is happening also in Wireframe mode.
