So in the V6 if you have text inside blocks and the place the blocks on different planes the text doesn’t show up. This doesn’t seem right to me. I know text on it’s own is supposed to do that but seems like text inside a block shouldn’t do that.
I’m not seeing this issue here in your file so I made a block with text in v5 and imported it as well as making the same in v6 directly and neither case had the problem. This is what I see here…
Can you check your display mode settings for the views where the text is missing? It’s as if Show Annotations is off but you still have the rectangle in these views so just check that the display mode is set to the defaults as a quick test. Also run the SystemInfo command and send back that info here please.
The GPU driver is from '13 so that may be the cause but I’ll need to get @stevebaer and @jeff in on this one to check if they have any thoughts on whether I’m right. Any ideas guys? I know block display is undergoing some changes.
Yeah it disappears in all views on my machine as well. So I guess they could be different issues. Updating the driver now I will let you know if that changes anything.
