Text Field text is now case sensitive?
Is it intentional? R4-6 wasn’t.
Yes it is intentional. We switched to a python based engine for evaluation which lets us do a whole lot more with text fields in V7. The limitation is that all of the text field functions need to be case sensitive.
Where I can find more info about how to “script” things like this CurveLength? I wonder what else is possible.
Hi Andrew - Start the Text command and in the dialog box, press the fx button. That will give you access to those text fields.
