Does anyone know the syntax or if it is possible to change the model units in the Area Function in the text field function. Current Syntax below, but can’t find a way to either change the model units or to multiple or divide the output so it changes from millimetres to Metres
Area =%<area(“816e993b-b964-4552-be79-043ac7dbf35d”)>%
I think we still need some work done before this is truly usefull for us. It is a much needed feature. I would also prefer an easy access to standard “rounding”, such as “floor” and “ceiling” plus a way to limit the number of decimals in “volume”, “area” & “curve lenght”.
Finally it would be preferable to use an objects “Rhino-name” over GUID (if such a name is assigned by the user (or GH). Ideally if you select multiple closed polylines (all with Rhino-names), you should also be able to create an editable “table” displaying the Name, Area, Curve-Lenght and GUID of them all. Please.
