Text editor in properties windows, not working so good here
Trying to edit text from this window is troublesome. Yesterday every time I hit the space bar it would send the next character into the command line, today it’s just makes everything disappear and hang. and missed strokes typed after that event.
I have a similar problem using V5 on Windows at work.
Philip
Hi Gustavo - I see this here as well - thanks for the report.
http://mcneel.myjetbrains.com/youtrack/issue/RH-32523
Do you see this in V5 or WIP?
I’ve been trying to duplicate it for a while and haven’t been able to
for me was on WIP. Let me check again…
…It’s working fine now :slightly_smiling: . If that changes I’ll report bad.
Great - Thanks.
I think it must have to do with something not directly related to the dialog but I don’t have an idea where to look.
Especially since it’s been seen in both v5 and WIP and the dialogs are different, it may be a side effect of something else.
Pascal saw it intermittently too, but not reliably.
Same problem here with last wip… any news from developers?
Yep, see that too… —Mitch
Thanks Mitch :+1: was thinking the problem was only on my pc.
Looking in the BugTracker, Lowell say that he cannot reproduce the problem…
Ciao!
Then there must be something wrong with Lowell’s PC :wink:
Same thing happens here - any text results in only one letter when editing text from the properties tab.
Ah! Correct! :wink:
Thanks, I see this too. Filed as http://mcneel.myjetbrains.com/youtrack/issue/RH-34591
I got my computer fixed and I see it now too.
