I recently noticed my text editor is super laggy when typing, even the cursor lags behind (it stays some letters behind before moving to the end).
Empty canvas, new document, up to date Rhino, up to date drivers, default text, 4 lines of text.
I’m attaching my system info.
Something I also noticed is that when moving the text object by dragging it, and instantly panning my view, I get the same lag.
Edit 01: no need to drag the text object, just by selecting it with click and panning the view lags, to the point the view moves after some seconds but the “hand” point never appeared.
Edit 02: typing in all caps seems to reduce the lag while typing as well as the lag from selecting and manipulating the text object
Disabling V-Ray had no effect on moving nor on typing.
Properties tab not selected did made a difference in selecting and moving text around, it made it light and smooth again.
HI Steve, I just did and tested: no change.
I made a video to better convey what I am experiencing.
You can clearly see how the view lags behind when panning immediately after selecting a text object.
Typing also lags behind: for a moment no typing appears and the word appear instantly. Cursor also lags behind.
Hello, I’ve been having this problem on and off for a few months too, and again this morning when editing a lot of text. I have the latest Rhino 6 build, latest GPU drivers, Win 10, etc.
Sorry don’t know if this is an option but when I was doing layout for engraving pages I had to do it all in a text editor then copy/paste into rhino, was impossible otherwise due lags.
Open word pad or any other text editor and do your text in there then copy and paste into Rhino.
RM
Hi @DavidEranen ,
I see problems when using text in Rhino. Maybe you can just bring up word pad or something that works and then just copy paste into rhino? I see huge problems in lagging and formatting but text has been problematic since V5 so I gave up. But recently I did a small amount of text in V7 and noticed problems with lagging right off the bat.
RM
