Text disappear from custom buttons after a while
Anyone else notice this? I’ve been using the latest beta for a few hours and not sure when it happened. And when this happens, the button cannot be edited anymore.
EDIT: Also, now when I quit Rhino, I notice how it updates the .rui file… but when I re-launch Rhino the toolbar looks normal again… CC @CallumSykes
EDIT: Any time I open the “edit buttons” and end up in the entire toolbar, a few random icons in it loose text for the session (unfortunately also writes to .rui even though there’s no change). But I think the first time I saw text disappear was through regular use, otherwise I wouldn’t have right-clicked to attempt to edit.
Also, I noticed that the text itself is less readable in V9 compared to the old V8 typeface…
GIF2
Plus, the line spacing is bigger, making it so that I can fit less in the same toolbar. :frowning:
GIF
EDIT: Noticed in the above animation that some buttons did get their labels reset too… again, something which gets fixed once I restart the Beta.
Hi.
I will try and reproduce this, it’s very odd :thinking:
YT here → RH-97200 Text disappear from custom buttons after a while
Today for some reason, my Extrude button refused to work, so I shift-right-clicked it to see if the command had migrated properly and it had. After doing that, the Extrude button began to work again, but about a third of my commands lost their text, so this is repeatable for me:
Not sure if this is related, but first time I’ve seen this! :laughing:
I was editing a few more buttons today (because I noticed another thing that was off):
(Why so many names for a single thing, and then the actual name gets ignored? Confusing!)
And after I made the above edit, about half a dozen labels disappeared, and something I haven’t seen in quite a while popped up (“Macro 31”, also a wrong name but one that V8 invented for a while until it was fixed in a service release).
The old system feels smoother, doesn’t it? There aren’t too many fields in it.
I’m working on removing almost all of the fields for simplicity now that I’ve got a handle on how a lot of this stuff works.
With your toolbars and layout I did see this happen today. It is VERY weird.
@eobet I managed to reproduce it and fix it, the build next Tuesday should fix this up. Thanks for reporting this!
