Text and Leaders visual selection bug
This bug has been in R6 for quite a few releases.
  1. Make a text or a leader
  2. Select it
  3. Change its justification in the properties to something else
  4. Click an empty space in the model space to deselect it
  5. It will visually stay selected.
To “reset” it - click on it again and click empty space.
@lowell
Mine does not do that.
When I click in space the highlighting goes away.
Please run SystemInfo and post the results.
Since this is display related, I suspect you have old display drivers.
Does the Notification panel suggest you update your display drivers?
It looks like Lowell was able to repeat the problem and has added a defect report.
Confusing.
