@GregArden
Continuing the discussion from TestSilhouette via RC:
Please try TestSilhouette with 15° through 65° draft in either the Top or Front views. The tangents aren’t created for the 2 NurbsSurface faces.
TestSilhouetteEx-171011.3dm (54.2 KB)
Thank you, Steve
Hi Steve - currently this test command pays attention to surface direction - if you explode this thing and use the Dir command to swap the UV on those two surfaces so that the normal matches them, the command will (should) work…
Dir
