just noticed that placing jpgs in rhino views is not working if using TestMetal.
If I use the background bitmap command nothing is showed in the viewport (turning off Metal shows the image.)
If using the picture command all I get is a blank white rectangle (again turning off Metal shows the image.)
SysINFO:
Rhino 8 SR0 2022-1-11 (Rhino WIP, 8.0.22011.12316, Git hash:master @ e61fc78d7ed6bc889c1402fc0b8bf4337d761825)
License type: Commercial, build 2022-01-11
License details: Cloud Zoo
Expires on: 2022-02-25
Apple macOS Version 12.1 (Build 21C52) (Physical RAM: 16Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: Macmini9,1
Language: en
Apple M1 (OpenGL ver:4.1 Metal - 76.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 10922 MB
Graphics: Apple G13G
Displays: Unknown (217dpi 2x), Unknown (108dpi 1x)
Graphics processors
Apple G13G
MateView (2560 x 1707 @ 60.00Hz)
Q27P1B (2560 x 1440 @ 60.00Hz)
USB devices
Dialog Semiconductor (UK) Ltd: MateView
HUAWEI: MateView Combo HID
EPSON: WF-7720 Series
Hauppauge: Nova-T Stick
Logitech: USB Receiver
APC: Back-UPS ES 700G FW:871.O2 .I USB FW:O2
Razer: Razer DeathAdder Elite
Western Digital: My Passport 071D
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_X.rhp “X Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Connections.rhp “Connections” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_Points.rhp “Points Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ConnectionsUI.rhp “ConnectionsUI” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STL.rhp “STL Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X.rhp “X Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_Points.rhp “Points Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp “RhinoRoslyn” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/MPlane.rhp “MPlane” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/Import_M.rhp “Import_M” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Squish.rhp “Squish” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_STL.rhp “STL Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.0.22011.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp “RhinoCPython” 8.0.22011.12316
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.22011.12316
