I’m unsuccesfully trying to set a blank Rhino plugin with Google Test.
Things I tried:
Create a c++ plugin using the wizard for VS
Added a project using the Google Test wizard
Added the source folder of the plugin into the include paths of the Google Test project
Added the .rhp file in the “additional dependencies” paths of the Google Test project
After these steps I’m getting LNK1107 invalid or damaged file.
I tried also to change the extension to .lib and change to static library.
This gives me LNK1104 can’t open ‘mfc100ud.lib’ and LNK2038 different _MSC_VER ‘1600’ differs from ‘1900’
I don’t really know how to proceed. Any suggestion or resource?
It’s basically a c++ testing framework. Recently, a plugin for visual studio was developed for testing integration with google test.
I kept trying to figure out how to make it work with a plugin. Since plugins (.rhp) need the Rhino environment to work, I suppose the only way would be creating a plugin and run the tests inside Rhino, and then capturing the standard output somehow
Is it possible to configure VS Unit Testing with a Rhino plugin? It looks to me like I would have the same problems for running the tests (we would have to run the tests from inside Rhino with a test plugin)
I was trying to achieve this some time ago and the conclusion I arrived was to create a test plugin as you say @Gerard2 and then execute “testing” commands with Rhino launched. I would like to use googletest or visual studio tests (or any other) to check my methods before packing the software in a more intuitive way.
Yes, something with VS integration would be great, Rhino is quite heavy for testing. If I’m not misunderstood Rhino 6 will be packed in a dll so we can do more stuff like this.
