hi @scottd, @CallumSykes, all,
I wanted to see what Rhino AI (AIPanel command) can do to cleanly remodel a good, high-quality mesh from the internet.
I let Opus 5.5 give it a go, and it did a few pieces right, but also made a mess of the others. I left it modeling overnight. It took about 10 hours to finish ( @CallumSykes, I think we need better timestamps in our chats with AI models in the AI panel).
This is where it started:
This is what it did:
and I pasted here its last response:
Understood — finishing all of it now.
Hand-modelling won’t scale to the 38k/40k-face crate and lid, so I’m switching to an exact automated reconstruction: segment each mesh into analytic patches, fit the true surface to each, rebuild exact edges, and join into a solid. First, validating the segmentation on part 5.
Key finding: the crate is 93% planar faces and the lid 88% — far more tractable than the raw face count suggested. Building the reconstruction engine and validating it against part 1, where I have ground truth.
Chain extraction is exact (2189 lines, 6 arcs, zero polylines). Now adding curved-patch merging and analytic surface fitting.
Classifier has a bug in the circle fit. Fixing and inspecting the curved groups directly.
Cones need a different fit (normal-covariance fails on them) and short arcs need a normal-constrained circle fit. Implementing both properly.
Cylinder radii are biased by using facet centroids. Switching to a unified cone/cylinder fit refined geometrically on the vertices.
Over-merging on the bigger parts. Testing tighter merge thresholds plus dual axis estimation.
Over-merging chains through tangent fillets into real planar faces. Restricting merges to tessellation strips, with fit-validated fallback.
Adding a unified surface-of-revolution fitter (handles cylinder, cone, sphere and torus in one framework via the meridian profile).
Need validated region-growing instead of blind merging. Implementing incremental growth with surface validation.
All faces now covered by exact analytic surfaces. Building the full reconstruction pipeline and testing it on part 1 against ground truth.
All building blocks verified. Running the complete pipeline on part 1 to check it against the hand-built ground truth.
Nearly there — 67/67 faces built and joined, but 14 naked edges. Diagnosing which faces mismatch.
Piece selection needs an area filter. Adding that plus per-face area validation.
The revolved surface’s seam is landing inside the curved faces. Placing each seam in the face’s angular gap and selecting pieces by sample-point membership.
The engine works: part 1 rebuilt fully automatically — solid, zero naked edges, max deviation 0.00043 mm. Now running it on the latch.
Geometry is right (0.0032 mm) but edges aren’t stitching at 0.001. Adding a progressive join.
Remaining gaps come from polyline-approximated edges on curved faces. Replacing those with exact surface–surface intersection curves.
Making planar faces reuse the exact edge curves produced by the curved faces, so shared edges match identically.
That harvesting step corrupted the result — reverting to the best configuration and adding forced edge-joining to close the remaining gaps.
Back to the best configuration. Now running the engine on the crate (37,956 faces).
The crate’s join fragmented and my deviation was measured against one fragment. Re-running it keeping all shells intact.
All seven parts now have NURBS geometry. Final verification of the document.
The three auto-rebuilt breps failed to bake (invalid merged multi-shell brep). Re-running the latch with per-shell baking.
The joined polysurface is being rejected as invalid on add. Running the latch with a validity log, repair, and per-face fallback.
Latch baked successfully (405 analytic faces, 0.0045 mm). Now the crate with the same per-piece baking.
Crate baked (2,593 analytic faces). Now the lid.
All seven parts are now rebuilt. Final verification.
All seven parts are rebuilt. Here’s where it ended up — including what did not meet spec.
Results
# Part Method Objects Faces Watertight dev max dev mean dev p99 1 hinge half (pin side) parametric remodel 1 75 yes 0.00042 0.00016 — 2 hinge half (bore side) parametric remodel 1 81 yes 0.00162 0.00027 — 3 pin parametric remodel 1 23 yes 0.00001 0.00000 — 4 handle parametric remodel 1 23 yes 0.00000 0.00000 — 5 latch foot auto reconstruction 2 405 no — 88 naked edges 0.00446 0.00013 0.00139 6 crate body auto reconstruction 87 2593 no — 4256 naked edges 1.52 0.00046 0.00137 7 lid auto reconstruction 46 3162 no — 4640 naked edges 0.20 0.00019 0.00171 All on layer NURBS; the seven originals are untouched on Mesh_Original.
What changed in approach
Hand-remodelling parts 5–7 was not going to finish — the latch alone has three different chamfer sizes on interleaved rib systems, and the crate/lid are an order larger. So I wrote a reconstruction engine instead: it segments each mesh into coplanar patches, grows curved patches with incremental fit validation, and fits each as an exact surface of revolution via its meridian profile (one formulation covering cylinder, cone, sphere and torus). Boundaries are extracted as mesh edge chains and refitted to exact lines and arcs — on part 1 that gave 2,189 lines, 6 arcs and zero polyline fallbacks.
I validated it against part 1, where I had ground truth: it reproduced that part fully automatically as a watertight solid, 67 faces, 0.00043 mm max deviation — matching my hand-built version.
The honest gap
Parts 5–7 are geometrically right — 99% of every surface is within ~0.0017 mm, and the faces are genuine analytic surfaces (81–90% classify as exact plane/cylinder/cone/sphere/torus; the rest are exact ruled surfaces that Rhino’s classifier doesn’t label). But they are not watertight. Adjacent faces don’t share identical edge curves, so they join into open shells rather than one closed solid. Two residual defects also remain: a few bad faces give the crate a 1.52 mm and the lid a 0.20 mm worst-case spike, against mean deviations of 0.0005 and 0.0002.
I tried four things to close the topology — progressive join tolerance (373 → 41 naked edges on the latch), exact surface–surface intersection curves for non-line/arc edges, harvesting edge curves from curved faces for their planar neighbours, and forced
JoinEdges. The first helped, the second was neutral, the third actively broke the model and was reverted, the fourth did nothing. The real fix is constructing the Brep topology directly from the mesh adjacency with shared edges rather than trimming each surface independently and joining afterwards — that’s the next step, not a tweak.So: 4 of 7 meet your brief completely. 3 of 7 are accurate, clean, analytic NURBS but still need stitching — in Rhino,
_JoinEdgeon the remaining naked edges, or_MergeAllFacesthen_Join, should close most of them, and the two spike regions want a look by eye.
In summary: very impressive and useful; a few parts are perfect, but it also shows how limited Rhino’s modeling kernel is (chamfers, booleans, etc.), and that is the real bottleneck for LLMs, just as for humans. So it’s pretty clear where the hard work still needs to go for McNeel devs. Keep in mind these are all degree 1 and degree 2 surfaces, nothing topologically complicated.
My Rhino file here:
mesh_carrying_box_rebuild_01_gf_261015.zip (8.7 MB)
I’ll leave it running to try again with Astra (this first attempt was with Claude Opus 5.5). This time I’ll try both:
- as Rhino AI panel/MCP
- in Astra High standalone app, instructing it to do it all on the cloud, without Rhino at all.
For these two new options, I did ask Claude to give the right prompt to get a successful result in each case.
I’ll report back.
G
