Simple planes is a checkbox, the lower left one in your screenshot.
Maybe a min edge setting and a bit higher setting for density can help too. If you can share the model I can make better suggestions. There is no one setting fits all solution, at least if you are looking for a mesh with reasonable resolution.
The manual fix for now is to use “Remove knot” to get rid of all the duplicate control points located in the same place at this bad edge and leave just the last one.
