Hi All,
Is it possible to use the tension/compression eliminator across multiple load cases. I.e. to eliminate members in tension in each load case (depending on the load case the members may be in tension or compression).
Kind regards,
Mitch
Hi All,
Kind regards,
Mitch
Hi Mitch,
at the moment (Karamba3D 1.3.1) it is only possible to consider one load-case at a time with the tension/compression eliminator.
Best regards,
Clemens
