Hello everyone, based on this file, ARC605_Fa16_Curve Pull - Drape and Constrain.gh (15.3 KB) I tried to rotate the middle curve 90 degrees. Whenever I do that however, the membran will only be upheld by the middle point, instead of the whole curve.
Do you know how to fix this?
Thanks in Advance!
That’s because the points on the OnCurve component are a internalised pointset (selected / green on the screenshot).
Here’s how I’d do that:
Some of the components migth not work when you open the file attached below. You might want to update your Rhino / Grasshopper installation.
ARC605_Fa16_Curve Pull - Drape and Constrain.gh (27.7 KB)
Thanks martin, this was very helpful!
Thanks for the heads up. Please click the Solution button
