Tensile relaxation with curve anchors
Hi. If you’re exploring tensile structures, you might also want to check out StructuralDesigner3D. Also based on Dynamic Relaxation, this plugin allows the design of tensile, pneumatic, and funicular structures.
The main difference is that it works entirely inside Rhino (no Grasshopper), which makes the workflow feel more direct: you can select points, curves, and meshes straight in the viewport without having to manage or search through endless lists of items in GH. Another key difference is that, for each structural typology, you only need to activate a single command.
For form-finding, that speed and simplicity can really help.
For more information and a tutorial, you can access this conversation:
