Hello
I am trying to form find a tensile membrane structure but with taking the cables and posts-if needed- in the process. is there an example file for using cables with membranes in kangaroo2 or kangaroo2Engineering ?
Unless Daniel has some other idea/way I don’t think that this is possible without code.
Study these images: white is the cable at rest pos, green the new cable (per anchor) after K2 did the job. In the C# captured above for these var cables the 3 distinct stiffness values are: B for Back, S for Side and F for Front (per module between the trusses).
But this is only the tip of the iceberg since in real-life an evaluation of the anchor plate aperture angle is the critical part for more than obvious reasons. I can hardy imagine how to do that without code.
For instance this … for cases like above is a no-no: what is required is a 2 part hinged anchor plate system due to the rather big aperture angle.
Thank you so much!
Search “tensile membrane, membrane, membrane form-finding” in this or (better) in the old (but dead) Forum.
See this as well
Membrane by Kangaroo component in Grasshopper - Grasshopper
Are you familiar with C#? If so post here an indicative layout.
