I’m fiddling about using the mouse wheel as an input, using the keyboard and mouse modules to intercept the events. The sketch below gives the idea.
For it to be useful, I would need to temporarily suspend the mouse wheel zooming the display. Does anyone have any suggestions how that may be done?
Best, Paul.
#! python3
import scriptcontext as sc
import Rhino
import Rhino.Geometry as rg
import Rhino.Commands as rc
import Rhino.Input.Custom as ric
import System
import System.Drawing
import System.Collections.Generic
import math
#r: keyboard, mouse
import keyboard
import mouse
class GetCircleRadiusPoint (ric.GetPoint):
def __init__(self, initial_radius):
ric.GetPoint.__init__(self)
self.line_color = System.Drawing.Color.FromArgb(255,0,0)
self.keydown = False
self.radius = initial_radius
def HookaKey(self, key):
keyboard.on_press_key(key, self.KeyboardDownfunc)
keyboard.on_release_key(key, self.KeyboardUpfunc)
def UnHook(self):
keyboard.unhook_all()
mouse.unhook_all()
def MouseWheelFunc(self, event):
if isinstance(event, mouse.WheelEvent):
#print('wheel:', event.delta, event.time)
self.radius += int(event.delta)*200
def KeyboardDownfunc(self, event):
if isinstance(event, keyboard.KeyboardEvent):
if not self.keydown:
mouse.hook(self.MouseWheelFunc)
self.keydown = True
def KeyboardUpfunc(self, event):
mouse.unhook_all()
def OnDynamicDraw(self, e):
cplane = e.RhinoDoc.Views.ActiveView.ActiveViewport.ConstructionPlane()
circle = rg.Circle(cplane, e.CurrentPoint, self.radius)
e.Display.DrawCircle(circle, self.line_color)
def RunCommand():
Change circle radius with mouse wheel while 'b' key is depressed
gcp = GetCircleRadiusPoint(400)
gcp.SetCommandPrompt('Radius')
gcp.ConstrainToConstructionPlane(False)
gcp.HookaKey('b')
gcp.Get()
gcp.UnHook()
if gcp.CommandResult() != rc.Result.Success:
return gcp.CommandResult()
radius = gcp.radius
center_point = gcp.Point()
gcp.Dispose()
cplane = sc.doc.Views.ActiveView.ActiveViewport.ConstructionPlane()
sc.doc.Objects.AddCircle(rg.Circle(cplane, center_point, radius))
sc.doc.Views.Redraw()
return rc.Result.Success
if __name__ == '__main__':
RunCommand()
