As the title says, I’d like to be able to temporarily turn off the points, so that one does not lose sight of the forest for the trees. Also the ability to add/remove objects to check against would be handy.
Hi Jim - you mean turn off the display of the colored points-n-hairs, right, not the input points (cause those can be hidden or even deleted once PtDeviation knows about them - just making sure)
https://mcneel.myjetbrains.com/youtrack/issue/RH-42093
Yeah, turn off the coloured points and hairs temporarily. I guess you can already toggle the hairs.
