I just wrote a quite complex DisplayConduit that allows user to see, select and move some points in the document.
I would like to let user move points by dragging them but i can’t: since i’m “just” enabling a custom displayConduit (no real object is added to the document), if user drags mouse in the viewport, he defines a selection rectangle.
Is there a way to temporarily disable selection by rectangle?
As usual… Thanks a lot to you all!
Yes! That’s exactly what i did!
This is the reason i need to de-activate Rhino standard selection mode…
Anyway it looks that there’s no solution, right?
Thanks @dale!
I know it’s been a while since you asked, but I recently ran into the same issue. To prevent default selection behavior and get rid of the selection rectangle just cancel out from your conduit before the default logic kicks in.
