Tekla Structural Designer doubling supports without an apparent reason
Good day community,
Is there a reason why the Tekla structural designer “Model” component doubles the amount of supports if the list of supports that are allocated are the correct number (in my case 20 going up to 40).
Hi
Are you creating columns and also creating supports at the base of those columns? In Tekla Structural Designer, when you create a column it will automatically create the support, so you do not need to create that yourself. This could be why they are doubled up.
