Tekla Structural Designer and Rhino Inside Revit
Good day Community,
Thanks for the great work and providing this source of information for newcomers like me.
I have a question regarding Tekla Structural Designer and Rhino Inside Revit. Is it possible to access the Tekla Structural Designer Live Link components when working through Rhino Inside Revit? I can access both individually, but not at the same time. Maybe it is obvious why not, but just wanted to confirm that is is/isn’t possible.
Thank you
Hi Hendre,
Do you mean the TSD components don’t show up if using Rhino.Inside.Revit? Or that they just don’t work?
Cheers,
-b
Hi Sebastian,
The previous description I gave was incorrect and require clarification. The components are available, but the information cannot be live linked to Tekla (see screenshot).
Hi Sebastian, I found the issue, had two of these components in the same script. Thanks for getting in touch, made me check what I was actually stuck with.
