Hello
Is it possible to get breps with properties from Tekla Reference Model (IFC reference model)?
I don’t think it’s possible via the GH-Link in it’s current state, might be possible soon.
I’m not 100% here but @sebastian.lindholm can give us a definitive answer when he sees this after the Easter break.
Thank You Oscar for your answer. I’m asking because there is possibility in Tekla to convert IFC file to native objects as beams,plates, items so maybe IFC objects should have their breps. But Sebastian can give us answer.
Might be some limitations in the API, we’ll find out
Hi Chris,
We can’t extract geometry from reference model objects. This is an API limitation as Oskar pointed out, it’s been reported but so far no resolution. The attributes you can read using the Get Property component, including the bounding box coordinates, but that’s as far as you can go.
Cheers,
Sebastian
Thank You
