Hi everyone,
How can I create a concrete wallin Tekla with some openings as shown below? I think it works if the opening touches the wall edge (like a door) but when they’re not (like a window) Tekla just show a full wall instead
example geometry attached in the gh file. Thank you!
ConcreteSlabExample.gh (10.8 KB)
This did the trick, probably be a better way for the positioning of the cuts and the slabs but you have to do something yourself
ConcreteSlabExample.gh (22.7 KB)
Also, my method of getting the cut outlines will only work if the cuts are inside the slab, not on the edge, like a door that goes all the way to the bottom… but works fine for this example.
thanks Oskar. I add this to the end of the workflow. So cut brep by door, create wall, then cut with windows. Works for me!
