When dropping the bolt component into the canvas, I get this error.
All other components work. All files are unblocked. I am note sure what is causing this error.
Any thoughts?
Hi Francisco
Probably you have installed ggTekla plugin and Tekla Live Link can`t connect with Tekla Structures. If You have installed ggTekla plugin you must uninstall it.
I have the same problem, what is ggTekla plugin?
Are you solved this problem?
This should now have been solved in this latest WIP that you can grab from Warehouse:
https://warehouse.tekla.com/#/packages/b940f663-806a-413d-a25f-8353d16a2f9d
Thanks @arthur_kocherov for testing!
Cheers,
Sebastian
