I’m making my first “big” project with Tekla Live Link with grasshopper. And a ended up with a bit of an issue. That might me easy to solve, but I don’t kno how to.
Context: It’s a parametric culvert wich when I update the geometry the rebar comes whith it.
The issue comes to, when I create a Item in tekla, using concrete item component in grasshopper. It gives a rondom name to the shape generated. As the snap below. And suddenly when I copy the part to another location, It dissapears.
But now I ended up in another issue. The red middle culverts need to be a variable array, wich will have rebar on all the units. But will be diferent in every color you see.
The gap that you see is where the reamin culverts needs to be.
So, I need to know how to approach to make the rebar for the red culverts to be placed in each one. Even when changing the number of middle Culverts (Red ones)
