Technical View Print Width
Hi Again!.
I was wondering if is there a way to print using the technical display mode, where the print width of the lines is controlled as per layer /object print attributes. It seems that Technical always prints a the same line width.
In the image attached I have two examples, on the left a PDF print using wire frame display mode (where a specific layer I have given 2mm width) and on the right the same object printed on technical. It would be nice to be able to control too the width by layer, or to give the option of.
(the object I printed is a top view of a simple object consisting of two polysurfaces)
