Technical Print color
So looks like there might be a bug in technical view display. If you have the print color set to a different color the “Intersection” lines still print according to the layer color.
Thanks.
I can duplicate that.
I’ll get it on the list.
As a work around, in the Technical display controls, Objects - Lines - Intersection color line usage section, you can set the color to your print color then it will work-around the bug.
