Why does Rhino compute technical drawing when the current display is shaded or even wireframe? It says this error message almost every time I move around my model…
Hi Arthur,
Technical mode calculation should only happen once in a file. Is this happening in just one file for you or all files? Can you share the file if it’s just this one. You can send it to tech@mcneel.com to my attention. I would also update your GPU driver as a first possible solution too.
