Is there any way to “Refresh”, for lack of a better term, the Technical Display Mode without restarting Rhino?
Hi Don- I suppose ClearAllMeshes will do something - looks like you’ll need to shift out of and back into technical to
get the display back… But, what do you need by Refresh?
This especially happens with layouts, if you copy and paste or cut and paste an object, the technical display gets all messed up, and the only way to fix it, I have found, is to close and reopen the file.
Thanks,
Don
So, set a detail to technical, activate the detail and copy an object to the clipboard and paste… to the same or another file? What actually happens to the display of the object, what am I looking for?
thanks,
Does this help?
Thanks,
Don
