Technical, Artistic, Pen view mode
I have problem switching to Technical, Artistic and Pen view mode. When turned on, cpu goes up to 100% and it take ages to redraw, basically never. Other modes works fine. Any suggestions? Simple geometry works pretty well but scene with more parts never. Don’t remember this issue from 5th version.
Hi -
Those display modes need an extra set of display meshes that need to be created and that needs to be done every time you open the model.
Apart from that, please post your SystemInfo details and post a file that is giving you troubles.
I cannot give you the file, it is confident. But it happens basically with every file that has more parts than few cubes.
Dell Precission 5530,
|Procesor|Intel(R) Core™ i7-8850H CPU @ 2.60GHz 2.59 GHz|
RAM|32,0 GB (použitelné: 31,8 GB)|
|Typ systému| 64bitový operační systém, procesor pro platformu x64|
Windows 10 Pro
Verze
Datum instalace
Build operačního systému
Windows Feature Experience Pack 120.2212.2020.0
Operační systém: Windows 10 Pro, 64-bit
Verze DirectX: 12.0
Procesor GPU: Quadro P1000
Verze ovladače: 461.40
Typ ovladače: DCH
Úroveň funkce Direct3D: 12_1
Jádra CUDA: 512
Taktovací kmitočet: 1303 MHz
Rychlost přenosu dat paměti: 6.01 Gbps
Paměťové rozhraní: 128bitové
Šířka pásma paměťové sběrnice: 96.13 GB/s
Celková grafická paměť k dispozici: 20357 MB
Vyhrazená video paměť: 4096 MB GDDR5
Systémová video paměť: 0 MB
Sdílená systémová paměť: 16261 MB
Verze systému BIOS videa: 86.07.63.00.23
@dyzajn the question was to run the Rhino command _SystemInfo and paste the text from the result. That’ll tell us better what Rhino thinks of your setup.
Rhino 7 SR4 2021-3-19 (Rhino 7, 7.4.21078.01001, Git hash:master @ a432d22ab7f0f7b53d157d578278070c8bf6eff4)
License type: Commercial, build 2021-03-19
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 32Gb)
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 10-28-2020 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P1000 (NVidia) Memory: 4GB, Driver date: 4-8-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.31
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-8-2021
Driver Version: 27.21.14.6231
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.4.21078.1001
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.4.21078.1001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.4.21078.1001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.4.21078.1001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.4.21078.1001
