Hello All,
im trying to do that:
with grasshopper,
does anybody knows how?
What have you tried so far?
Also, this looks like something that would be simple to make just in Rhino without Grasshopper, by drawing a parabola, rotating it, extruding to a point, then array polar.
Classical sort of Felix Candela work
https://www.grasshopper3d.com/m/discussion?id=2985220%3ATopic%3A1619058
The basic is to first search with a search engine.
thank you!
The difficult part is the roof intersection… This model breaks too easily. Careful adjustment of the ‘Angle’ slider (and/or Z-slider) often gets a fair result with different polygons.
Thank you very much!
Amazing!
Thank you all
Solves the intersection issue by using a straight line for the “valleys” thanks to Extrude Point. This is an R5 version of your code, no relays.
