TArc Question
Hi I’m attempting to make this elongated bean shape (in black on the left). I’m trying to make it work using the TArc definition but the external arc needs to be flipped in the negative (which doesn’t seem possible?). Any ideas on how best to make this?
You could also create a pipe with round ends around just one curve and then get the section curve of the pipe and XY plane…
Thank you this worked perfectly!!
Thanks, please click the Solution button :slight_smile:
