Tapered offset Surface Question
I noticed that if I create a tapered offset of a degree 5 by degree 5 surface I get a degree 3 by degree 3 surface. In fact, the result seems to be a 3X3 surface no matter what the degree of the original surface.
Is there any way to change this so that the degree of the offset surface matches the degree of the original surface ? I found this functionality useful 30 years ago when I was using CATIA and needed to make solid geometry bounded by the two surfaces. It made for much cleaner solids.
Also, are there plans to enable history with this function in the future ?
Chris Holtorf
