Taper question
I want to model a SubD torus into a ring shank, the top of the ring should be ~
TorusTaper.3dm (221.3 KB)
7mm and I want to use taper so that the bottom width of the torus is reduced to 4mm. I use the taper command. I get the top and bottom dimensions OK, but the taper is also applied such that the torus is now also V shaped in the axis 90 degrees from the applied taper, i.e. the torus is now egg shaped. Are there settings that prevent any distortion except for the
7x4mm taper to the torus in one axis only?
It can be done with Wirecut but that creates very harsh flat sides. and it becomes a closed polysurface.
Solved: Use Flat option
