Taper in degrees, not distance
I’m trying to optimize a closed/solid object for injection molding and need a add a 3 degree draft/taper to all walls.
I can’t seem to figure out how to do this with the" "taper command as it only appears to take a distance and not a degree and the object is complex enough that just thinking about doing the math hurts.
Any idea on how to make ‘taper’ take a degree input or is there another feature I should use?
Thanks!!
