Tangent surfaces using offset surfaces
Hi! How can I join the edges of surfaces so that when I use surface offsets, they remain tangent and do not separate?
hi @palma are the surfaces tangent to start with? Offsetsrf will not extend surfaces
Yes, in the main model the edges of the surfaces are tangent, when I perform the surface offset, they separate…
Can you send the model?
OffsetSrf.3dm (862.9 KB)
OffsetSrf.gh (30.6 KB)
I don’t see that here:
So I must first make the original surfaces tangent to each other and then perform the srf offset?
yes, otherwise, if there is a tangent difference, the surfaces are going to separate or intersect.
