Tahoe: large file save dialog
I am getting a different bug, since the OS update, the window which comes up when you go to save a file is huge, it takes up the whole width of my screen and occasionally is wider than the display itself, it isn’t an issue I am having in other applications or when exporting only the initial save or save as function.
RH-89872 Tahoe: large save dialog that grows
Was this solved? I have this issue too. I see that the link says fixed for 8.25, but I am on 8.24 and see no updates?
Hi scroggin -
8.25 currently is a Service Release Candidate. You can change your update frequency to switch to that release cycle.
Thank you
