tags are crashing in the textures panel on win 8.13.24317.13001 and macos 8.13.24317.13002
the behavior is that you get a crash (hard crash on macos, with no reporter) whenever any field is changed on a texture that has a tag, or while attempting to add a tag, as shown here:
no similar crash occurs (as far as I have seen) in the materials or environments panels, which allows setting up textures w/tags to test this, and also removing tags from textures to work around the problem
stacktrace (macos)
2024-12-03 20:51:16.847 Rhinoceros[49735:6941693] Microsoft.macOS: Aborting due to trying to marshal managed exception: Object reference not set to an instance of an object. (System.NullReferenceException) at RDK.Controls.ThumbnailUI.RdkThumbnaillistViewModel.UpdateStringsAndTinyIcons(InternalThumbData data, RenderContent content) in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/rhino4/Plug-ins/RDK_EtoUI/Controls/ThumbnailUI/rdk_thumbnaillist_viewmodel.cs:line 1345 at RDK.Controls.ThumbnailUI.RdkThumbnaillistViewModel.UpdateInternalThumbnailData(InternalThumbData data, RenderContent content) in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/rhino4/Plug-ins/RDK_EtoUI/Controls/ThumbnailUI/rdk_thumbnaillist_viewmodel.cs:line 1313 at RDK.Controls.ThumbnailUI.RdkThumbnaillistViewModel.UpdateThumbnailData(RenderContent content) in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/rhino4/Plug-ins/RDK_EtoUI/Controls/ThumbnailUI/rdk_thumbnaillist_viewmodel.cs:line 1300 at RDK.Controls.ThumbnailUI.RdkThumbnaillistViewModel.OnDataChanged_ContentParam(EventInfoArgs args) in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/rhino4/Plug-ins/RDK_EtoUI/Controls/ThumbnailUI/rdk_thumbnaillist_viewmodel.cs:line 1878 at RDK.Controls.ThumbnailUI.RdkThumbnaillistViewModel.OnDataChanged(Object sender, EventInfoArgs args) in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/rhino4/Plug-ins/RDK_EtoUI/Controls/ThumbnailUI/rdk_thumbnaillist_viewmodel.cs:line 1952
system info
Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Not For Resale Lab, build 2024-11-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 158GB)
.NET 7.0.0
Computer platform: LAPTOP - Plugged in [75% battery remaining]
Primary display and OpenGL: NVIDIA RTX 4000 Ada Generation Laptop GPU (NVidia) Memory: 12GB, Driver date: 10-8-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 553.24
Primary OpenGL: NVIDIA RTX 4000 Ada Generation Laptop GPU (NVidia) Memory: 12GB, Driver date: 10-8-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 553.24
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 6-10-2024 (M-D-Y).
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-8-2024
Driver Version: 31.0.15.5324
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24317.13001
