Hi, I added new parameters to the doors I worked with and I would like it to appear in the tables, is there such a possibility
Hi @11170 you can list custom parameters as long as they have been created as Document Parameters or Style parameters. If they have been created as Object parameters they can’t be listed in tables.
In the other cases, you just need to go to the table styles, select the property field to link with that parameter, and under the “Source” tab, select the object type, the style (if the parameter has been created by style) and the parameter:
Great thanks!
בתאריך יום ג׳, 22 במרץ 2022, 10:33, מאת Francesc Salla via McNeel Forum <mcneel@discoursemail.com>:
