T-splines rhinocores
Hi guy
You help me implement the steps of the remove crease command
I tried that plane without edge.
thanks
gonna need some more info to be helpful… can you clarify what is happening, or what you are trying to do?
@vuthianhdao12 If I remember correctly when you tab into smooth mode, on the keyboard the numbers 1, 2 & 3 will adjust the visual smoothing and if you accidentally hit the 1 it will stay blocky even though you’re in smooth mode.
@ra_mull How did you do it?
@theoutside elect plane–> shortcut key TAB
hit the tab key and hit 1,2,3 keys and see if there is any effect.
