Thank you, Kyle. It sounds good. It seems I don’t need to spend too much extra time to refresh my brain.
As someone who does a lot of work in Fusion360 and uses the SubD/Tspline/Form workspace there in parallel to capabilities in Rhino/Grasshopper to algorithmically generate forms and work much more easily with patterning, I’m trying to figure out how to optimally get Rhino SubD’s over to the Form workspace.
Am I missing any tips and tricks for how to get the geometry between the two tool sets?
extract the control polygon then export it from Rhino as obj.
go into fusion, and convert that control polygon to subd (tsplines) I assume you can do this, but full disclosure, I’m not a Fusion user.
Thanks Kyle, that helps tremendously to keep the poly count/surface counts down!
