System.Uri not Working
I’m having issues importing System.Uri in Python after updating to Rhino WIP 8.0.22263.16305, 2022-09-20
URI error
Seems like a similar issue to: RH-66656
Anyone else having this problem?
import System
import clr
clr.AddReference("System.Runtime")
uri = System.Uri("https://www.rhino3d.com/")
print(uri)
– Dale
Thanks for the simple fix @dale !
:slight_smile:
Thanks for reporting the issue, this is likely due to the change to using .NET 6 runtime by default. I’ve created RH-70626 to fix that up, as we shouldn’t require you to add a new reference just to use basic types.
