System.DllNotFoundException: Could not load 'DLL 'rhcommon_c
Hello Everyone,
I am developing software that will external access my Rhino and Grasshopper project using the C# Console Application. I want to use RhinoCommon API classes and methods in this software. How can I use it?
In addition, I have installed RhinoCommon.dll in this software and when I want to use the libraries there, I get the error “System.DllNotFoundException: Could not load 'DLL ‘rhcommon_c’: The specified module could not be found”'. How can I solve this problem?
Ekran Alıntısı
Program_C#.txt (1.2 KB)
Thanks for your help.
Hello
if the program is not executing inside Rhino or Grasshopper you don’t have access to this API
so you must use another dll that has less function
before it was Rhino3dmIO
And now Rhino3DM
For external access, you might want to use Rhino.Inside
Here is a basic sample
Thank you your reply. I solved the problem with rhino.inside
