System.AccessViolationException when reading doc.RenderMaterials[]
i get a ‘System.AccessViolationException’ when i run the plugin, accessing doc.RenderMaterials[0] for the SECOND time. First time works.
Also when running the plugin once with multibe objects selected, no problem.
There is not much documentation on RenderMaterials …
Hope someone can help. Thanks.
       if (objRm == null)
                    obj.RenderMaterial = doc.RenderMaterials[0];
                    obj.CommitChanges();
                    obj.Attributes.MaterialIndex = findsRM;
full code:
        Rhino.Input.Custom.GetObject go = new Rhino.Input.Custom.GetObject();
        go.SetCommandPrompt("Select objects to apply 18ct red gold");
        go.GroupSelect = true;
        go.SubObjectSelect = false;
        go.EnableClearObjectsOnEntry(false);
        go.EnableUnselectObjectsOnExit(false);
        go.DeselectAllBeforePostSelect = false;
        go.GetMultiple(1, 0);
        int findsRM = doc.Materials.Find("18ct red gold", true);
        for (int i = 0; i < go.ObjectCount; i++)
            Rhino.DocObjects.ObjRef objref = go.Object(i);
            Rhino.DocObjects.RhinoObject obj = objref.Object();
            if (findsRM == -1)
                Rhino.DocObjects.Material rg18ct = new Rhino.DocObjects.Material();
                rg18ct.Reflectivity = 1;
                rg18ct.ReflectionColor = System.Drawing.Color.FromArgb(255, 187, 132);
                string rg18ctName = "18ct red gold";
                rg18ct.Name = rg18ctName;
                rg18ct.CommitChanges();
                var idrg18 = doc.Materials.Add(rg18ct);
                var rmrg18 = Rhino.Render.RenderMaterial.CreateBasicMaterial(doc.Materials[idrg18]);
                doc.RenderMaterials.Add(rmrg18);
                obj.RenderMaterial = rmrg18;
            else
                var objRm = obj.RenderMaterial;
                if (objRm == null)
                else
        doc.Views.Redraw();
        return Result.Success;
Hi @seppeldue,
Can you include a sample model that this command repeats the issue on?
– Dale
Hi @dale,
Thanks for looking at my problem.
A new rhino scene with 3 boxes (or spheres) with no material is sufficient.
Run the command on each of these separatly.
On the first run a new material is created. On the 2nd the (now) existing material is used. When you run it the 3rd time on the last object the exception happens.
Strangely, when running the command on multiple objects, it works fine…
-Seb
Hi @seppeldue,
Thanks you. I am able to repeat this and I have logged the issue.
https://mcneel.myjetbrains.com/youtrack/issue/RH-57582
– Dale
