Hi! I’ve been having difficulties when iterating RenderMaterialTable and got this error.
My aim is to know if a specific render material exists in the currently opened file to modify it.
Here another error when trying the same behaviour (iterating through the RenderMaterialTable), in this case for purging the non-using RenderMaterials.
You are changing the RenderMaterials
table while iterating over it. You should not do that as it causes crashy behavior as you have noticed.
You need to first collect the materials in a list you want to delete in one loop, then loop over the list of materials to delete and remove them from the RenderMaterials
table.
This is a common pattern because you never should change a collection you’re iterating over.
@nathanletwory Thanks for the answer!
I’ve modified the code according to your advice, but the problem remains. In the first loop, I just add the material to another new list, but the error appears when accessing the property “Name” of the render material.
public static void CleanRenderMaterials(RhinoDoc doc)
var matListToDelete = new List<RenderMaterial>();
for (int i = 0; i < doc.RenderMaterials.Count; i++)
var renderMat = doc.RenderMaterials[i].Name;
var inUse = false;
for (int j = 0; j < doc.Layers.Count; j++)
if (doc.Layers.FindIndex(j).RenderMaterial != null && doc.Layers.FindIndex(j).RenderMaterial.Name == renderMat)
inUse = true;
if (!inUse)
matListToDelete.Add(doc.RenderMaterials[i]);
for (int j = 0; j < matListToDelete.Count; j++)
doc.RenderMaterials.Remove(matListToDelete[j]);
What RhinoCommon and Rhino version are you using? Rhino command _SystemInfo
output would be great.
I’m developing this plugin for Rhino 6 & 7, but I’m testing it in Rhino6.
SystemInfo report
Rhino 6 SR35 2021-8-10 (Rhino 6, 6.35.21222.17001, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Comercial, build 2021-08-10
License details: Cloud Zoo. In use by: Pedro Cortes (McNeel)
Windows 10.0.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: PEDRO-WIN
Primary display and OpenGL: AMD Radeon Pro 5300M (AMD) Memory: 4GB, Driver date: 11-13-2019 (M-D-Y). OpenGL Ver: 4.6.13571 Compatibility Profile Context FireGL 19.30.03.05 26.20.13003.5002
> Integrated acclerated graphics device with 7 adapter port(s)
- Laptop lid is possibly closed
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 11-13-2019
Driver Version: 26.20.13003.5002
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Users\pedro.cortes\Desktop\UIMplugin\src\UIM.Rhinoceros\bin\UIM.Rhinoceros.rhp “UIM” 1.0.0.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.35.21222.17001
I just tested with a simple file with seven materials in, but no crash:
import scriptcontext as sc
for rm in sc.doc.RenderMaterials:
print rm.Name
Maybe you could change your code to do a foreach
instead? I am not sure how well the index accessor works in loops (it should obviously).
foreach(RenderMaterial rm in doc.RenderMaterials)
// ... your checks here
if (!inUse)
matListToDelete.Add(rm);
Excelent @nathan !
Changing the for loop to a foreach one solved the problem!
I guess the problem is in the index accesor, as you predicted…
Glad that works for you!
