Synchronize values in Eto forms
I’m working on a custom Eto form with GhPython and looking to synchronize values from both controls, in this case a slider and a numeric updown
Snag_21890ad0
When slider value is changed, the numeric should update as well as the oposite, when the numeric value changes, the slider updates too, keeping them syncronized.
So far I’ve created the controls but not sure how to syscronize both, does anyone knows how to achieve this?
Here’s the code
import Rhino
import System
import Rhino.UI
import Eto.Drawing as drawing
import Eto.Forms as forms
class OptionsPanel(forms.Form):
    def __init__(self):
        self.Padding = drawing.Padding(10)
        self.Size = drawing.Size(350,100)
        self.m_slider = forms.Slider()
        self.m_slider.MinValue = 1
        self.m_slider.MaxValue = 100
        self.m_slider.Value = 1
        self.m_slider.ValueChanged += self.OnSliderValueChanged
        self.m_numeric_updown = forms.NumericUpDown()
        self.m_numeric_updown.DecimalPlaces = 0
        self.m_numeric_updown.Increment = 1
        self.m_numeric_updown.MaxValue = 100.0
        self.m_numeric_updown.MinValue = 1.0
        self.m_numeric_updown.Value = 1
        self.m_numeric_updown.ValueChanged += self.OnSliderValueChanged
        layout = forms.DynamicLayout()
        layout.Spacing = drawing.Size(5, 5)
        layout.AddRow(self.m_slider, self.m_numeric_updown)
        layout.AddRow(None)
        self.Content = layout
    def OnSliderValueChanged(self, sender, e):
        ghenv.Component.ExpireSolution(True)
    def GetNumber1(self):
        return self.m_slider.Value
    def GetNumber2(self):
        return self.m_numeric_updown.Value
if show == True:
    if 'form' in globals():
        form.Close()
    form = OptionsPanel();
    form.Show()
    value1 = form.GetNumber1()
    value2 = form.GetNumber2()
Each control should have its own function ‘OnXXXValueChanged’. When one function is called due to change of one control, set the value on the other control and vice versa.
Check this code
Thanks @seghierkhaled
Actually looking into that code helped also to learn other stuff, very interesting to explore the possibilities available on these forms.
Another question off-topic, do you know how to load it on the center of Rhino viewport?
I’ve looked for it but just found the position based on the screen, not on Rhino itself.
Hi @mats_magnunson, see this example which works without event bubbling.
_
c.
That’s a far more elegant solution indeed! Thanks
This is very good, thank you for sharing that line of code.
